TRANSMISSION REBUILT DVD, TRANSMISSION REBUILT DVD |
BAO B |
Jan 6 2012, 11:31 AM
Newbie Group: Members Posts: 43 Joined: 6-January 12 From: FLORIDA Member No.: 13,967 Region Association: None |
HI,
BRAND NEW TO FORUM. LOOKING FOR TRANSMISSION REBUILT DVD. APPRECIATE ANY INPUT. THANKS, BAO B |
Dr Evil |
Jan 6 2012, 06:31 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Hi Bao,
Your DVD is on its way as of tonight. For your question, which oil seal? If the surface that the seal sits on is not smooth, you can smooth it out with some fine sand paper and some time. If there is galling then you can fill it in with JB weld and smooth it with sand paper. Any pics of the surface of the oil seal area? |
BAO B |
Jan 6 2012, 09:24 PM
Hi Bao, Your DVD is on its way as of tonight. For your question, which oil seal? If the surface that the seal sits on is not smooth, you can smooth it out with some fine sand paper and some time. If there is galling then you can fill it in with JB weld and smooth it with sand paper. Any pics of the surface of the oil seal area? DR. EVIL THANKS FOR THE REPLY. THE 2ND PIC WITH THE SHAFT STICKING OUT IS THE CLEAREST ONE. YES, INDEED I HAVE TRY SMOOTHING IT OUT WITH SAND PAPER AND JB WELD TO FILL THE LOW SPOT AND SAND TO SMOOTH OUT. YET, WHEN INSTALLING NEW SEAL IT TEAR EVERY SINGLE TIME. WHAT IS DIFFICULT IS THE MAIN SHAFT IN THE CENTER OF THE HOLE GIVING YOU VERY LIMITED SPACE TO REALLY DO A GOOD JOB TO SMOOTH THE SURFACE. MAY BE IF I REMOVE THE GEARS AND THUS THE MAIN SHAFT IS OUT, THAT WILL GIVE MORE ROOM FOR ME TO WORK ON THE DAMAGED SURFACE. IF I REMOVED ALL THE GEARS AND SEND YOU JUST THE CASE, CAN YOU PERFORM THE REPAIR AND INSTALL THE NEW OIL SEAL? JUST A THOUGHT FOR NOW. THANKS AGAIN BAO B |
Lo-Fi Version | Time is now: 27th September 2024 - 02:17 PM |
