TRANSMISSION REBUILT DVD, TRANSMISSION REBUILT DVD |
BAO B |
Jan 6 2012, 11:31 AM
Newbie Group: Members Posts: 43 Joined: 6-January 12 From: FLORIDA Member No.: 13,967 Region Association: None |
HI,
BRAND NEW TO FORUM. LOOKING FOR TRANSMISSION REBUILT DVD. APPRECIATE ANY INPUT. THANKS, BAO B |
Dr Evil |
Jan 9 2012, 09:17 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
BAO, the new seals do bunch up on the outside diameter when installed. This is not a problem as they still seal. If you can feel roughness in the seal bore, then it needs addressed. If not, then you are good to install with PVC pipe, lube outside of seal with vasoline or oil, and if it bunches a little on the outside, that is not a problem.
BAO B |
Jan 9 2012, 09:47 AM
BAO, the new seals do bunch up on the outside diameter when installed. This is not a problem as they still seal. If you can feel roughness in the seal bore, then it needs addressed. If not, then you are good to install with PVC pipe, lube outside of seal with vasoline or oil, and if it bunches a little on the outside, that is not a problem. Dr Evil, I'm leaving it up for you to decide once i removed the gears and send the case to you. Without any experience I'm not in position to take any chances. With your experience and knowledge I can sleep much better. Any way i will post a damaged seal that i installed so we can view it. I will study the video once i get it and proceed from there. Thanks again, Bao B |
Lo-Fi Version | Time is now: 27th September 2024 - 02:16 PM |
