TRANSMISSION REBUILT DVD, TRANSMISSION REBUILT DVD |
BAO B |
Jan 6 2012, 11:31 AM
Newbie Group: Members Posts: 43 Joined: 6-January 12 From: FLORIDA Member No.: 13,967 Region Association: None |
HI,
BRAND NEW TO FORUM. LOOKING FOR TRANSMISSION REBUILT DVD. APPRECIATE ANY INPUT. THANKS, BAO B |
Dr Evil |
Jan 13 2012, 09:22 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
You have the wrong rod selected. You have pushed in the 2-3 rod to 3rd gear. The 4-5 rod is the one on the left of the 4th pic. You will need to reach in and put the trans back into neutral, then push the correct rod in. Then it should slide out pretty easily (IMG:style_emoticons/default/smile.gif)
Another tip is to pull the shifter rod out of its holder in the case so that it is just flopping around. That will allow for more movement when you pull the stack (about 30# for the assembly). |
BAO B |
Jan 13 2012, 09:44 AM
You have the wrong rod selected. You have pushed in the 2-3 rod to 3rd gear. The 4-5 rod is the one on the left of the 4th pic. You will need to reach in and put the trans back into neutral, then push the correct rod in. Then it should slide out pretty easily (IMG:style_emoticons/default/smile.gif) Another tip is to pull the shifter rod out of its holder in the case so that it is just flopping around. That will allow for more movement when you pull the stack (about 30# for the assembly). Thanks for the quick reply, I feel terrible selecting the wrong rod.. I guess i just have to learn from it. Now, how do I "reach in and put the trans back in neutral"?? I think the opening of the fork (removed) is where we start to set it back to neutral. And yes, the shifter rod is out of its holder and are flopping around. Thanks so much for helping out. Bao B |
Dr Evil |
Jan 13 2012, 05:02 PM
You have the wrong rod selected. You have pushed in the 2-3 rod to 3rd gear. The 4-5 rod is the one on the left of the 4th pic. You will need to reach in and put the trans back into neutral, then push the correct rod in. Then it should slide out pretty easily (IMG:style_emoticons/default/smile.gif) Another tip is to pull the shifter rod out of its holder in the case so that it is just flopping around. That will allow for more movement when you pull the stack (about 30# for the assembly). Thanks for the quick reply, I feel terrible selecting the wrong rod.. I guess i just have to learn from it. Now, how do I "reach in and put the trans back in neutral"?? I think the opening of the fork (removed) is where we start to set it back to neutral. And yes, the shifter rod is out of its holder and are flopping around. Thanks so much for helping out. Bao B Bao, if you look at the pics in my build thread you will see how neutral looks through the side hole. Basically, put the shaft you moved back to where it was. Then, move the other shaft. |
Lo-Fi Version | Time is now: 27th September 2024 - 02:18 PM |
