TRANSMISSION REBUILT DVD, TRANSMISSION REBUILT DVD |
BAO B |
Jan 6 2012, 11:31 AM
Newbie Group: Members Posts: 43 Joined: 6-January 12 From: FLORIDA Member No.: 13,967 Region Association: None |
HI,
BRAND NEW TO FORUM. LOOKING FOR TRANSMISSION REBUILT DVD. APPRECIATE ANY INPUT. THANKS, BAO B |
Dr Evil |
Jan 14 2012, 08:24 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Bao,
you have it all set to come out. It looks as if your shifter shaft is caught. Make sure it is loose. You have 1st selected as well which keeps the gears from turning at all (you have both 5 and 1 selected). This is not a problem, but it may be easier if you pull the 1st slider back to neutral and then try to remove the stack. There is nothing to hold it in the case other than the shifter rod getting hung up. You just need to pull up and wiggle a little (IMG:style_emoticons/default/smile.gif) If you think this is hard, wait until you have to put it back in (IMG:style_emoticons/default/smile.gif) ....watch the DVD (IMG:style_emoticons/default/wink.gif) |
BAO B |
Jan 14 2012, 09:24 AM
Bao, you have it all set to come out. It looks as if your shifter shaft is caught. Make sure it is loose. You have 1st selected as well which keeps the gears from turning at all (you have both 5 and 1 selected). This is not a problem, but it may be easier if you pull the 1st slider back to neutral and then try to remove the stack. There is nothing to hold it in the case other than the shifter rod getting hung up. You just need to pull up and wiggle a little (IMG:style_emoticons/default/smile.gif) If you think this is hard, wait until you have to put it back in (IMG:style_emoticons/default/smile.gif) ....watch the DVD (IMG:style_emoticons/default/wink.gif) Dr. Evil, I will pull the 1gear back to neutral and will make sure that the shifter rod is loose and not getting caught. From this point i'm confident as you stated that "nothing is holding up in the case" and will proceed on forcing it out. Thanks Bao B. |
Lo-Fi Version | Time is now: 27th September 2024 - 02:17 PM |
