Primer Question, Prime now, drive, paint later. |
ruby914 |
Feb 26 2012, 02:47 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
OK, I have my flares on.
I am fumbling through the clean up body work that goes with that and finding other body work that is needed as I go. Cass Nawrocki's book has already helped. The thing is, this car is one of my (2) 914 DDs In order for me to get clean lines on the body I need to remove the last 3, 4, 5 or 6 paint jobs. I have some 5 Star 5425 X Treme 2K Direct to metal Primer Filler/ Sealer. After I go down to the metal and spray with the sealer mix ratio, can I trust this to drive the car? Even park out side in the moist air, in the rain??? Then paint later, 6 months, 1 year later ?? What can I get away with? (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
scotty b |
Feb 26 2012, 10:32 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
If you can keep it inside and not drive it when it is wet, you'll probably be fine. But if it gets wet once it will not hold up. I would advise against it, do as Zach suggested and sand the car down to the original paint and work up from there unless you really want it stripped bare.
Lo-Fi Version | Time is now: 27th September 2024 - 05:36 PM |
