> Effutuo build, Ok, enough brow beating. here you go...
effutuo101
post Mar 9 2012, 10:44 AM
(IMG:style_emoticons/default/dry.gif)
So, last year I picked up Ugmo. After a short stint, Rich D. came up with this car. As it already had a lot of what I wanted to do to my ride, I talked to Rich and we traded off Ugmo.
Let the cutting and welding begin.
We would need:
new floors welded in
cut off the remaining fenders
GT kit welded in
Media blast
primer
The eventual build would have
Fiberglass fenders, hoods, rear bumper
suby motor
Low maintenance
easy for the wiffy to drive
Lets begin
effutuo101
post Mar 9 2012, 11:50 AM
The final texture is just like rhino lining. I am sure it would stand up. But, the nice thing is you can paint right over it. I will probably add some sound material to the low spots just to even out the floor as well as the back panel.
There are 4 layers on the fire wall. Two sound and two heat on each side. Only two layers of sound and heat on the floor.
my rear bumper just arrived. But, I have to go do some work downtown. Maybe a mock up later today...
effutuo101   Effutuo build   Mar 9 2012, 10:44 AM
effutuo101   so, the work began with the car on the rotisserie.   Mar 9 2012, 10:45 AM
effutuo101   more glass fitting   Mar 9 2012, 10:46 AM
effutuo101   continue   Mar 9 2012, 10:47 AM
effutuo101   and more   Mar 9 2012, 10:48 AM
effutuo101   more   Mar 9 2012, 10:49 AM
effutuo101   floor pans finally welded in. Car was media blaste...   Mar 9 2012, 10:50 AM
effutuo101   finish fitting fenders   Mar 9 2012, 10:52 AM
effutuo101   you can fit two 914's in a single car garage.....   Mar 9 2012, 10:53 AM
effutuo101   had to pack in the project for a few months due to...   Mar 9 2012, 10:54 AM
effutuo101   the new 914 hover craft.. and a quick trip to the ...   Mar 9 2012, 10:56 AM
effutuo101   ok, back to work... test fit....lots of stuff...   Mar 9 2012, 10:57 AM
effutuo101   Rich doing more welding... oh, I need more air......   Mar 9 2012, 10:59 AM
effutuo101   ok, maybe too much...naw... I need more air!   Mar 9 2012, 11:00 AM
effutuo101   Lizard skin going in.   Mar 9 2012, 11:01 AM
effutuo101   and some more...   Mar 9 2012, 11:17 AM
PeeGreen 914   :Qarl: It's getting close   Mar 9 2012, 11:17 AM
effutuo101   lizard skin...check.. i should clean my phone lens...   Mar 9 2012, 11:18 AM
effutuo101   ok, one more then back to work. color selection pr...   Mar 9 2012, 11:20 AM
effutuo101   so, I decided I could lose some more weight. I am ...   Mar 9 2012, 11:23 AM
RiqueMar   I'm not a fan of side air intakes, but that...   Mar 9 2012, 11:26 AM
effutuo101   Stitch...Mostly evil...   Mar 9 2012, 11:26 AM
gothspeed   Wow :)!!! Does the lizard skin need ca...   Mar 9 2012, 11:33 AM
jim_hoyland   Looking good ! :) Thanks for shaing. I like t...   Mar 9 2012, 11:48 AM
effutuo101   The final texture is just like rhino lining. I am ...   Mar 9 2012, 11:50 AM
effutuo101   @ Jim, yes, I almost did the same. But, given the ...   Mar 9 2012, 11:51 AM
effutuo101   And now my doors are back from the sand blasters. ...   Mar 9 2012, 11:52 AM
Ferg   Wow, Cool! :woohoo:   Mar 9 2012, 11:56 AM
gothspeed   Thanks for the info effutuo101 :)!! I thin...   Mar 9 2012, 12:14 PM
effutuo101   @ Ferg! :worship: any new projects? @ goth. ...   Mar 9 2012, 12:38 PM
gothspeed   ................. @ goth. spray lizard skin firs...   Mar 9 2012, 03:44 PM
effutuo101   ................. @ goth. spray lizard skin fir...   Mar 9 2012, 06:55 PM
Ferg   @ Ferg! :worship: any new projects? @ goth....   Mar 9 2012, 03:55 PM
audio_file   Looking great man! If you need an extra pair o...   Mar 9 2012, 01:50 PM
jcambo7   Sweet! Finally! :poke: :Qarl: :popcorn...   Mar 9 2012, 02:47 PM
mrbubblehead   nice work chris, how did you attach the fiberglass...   Mar 9 2012, 08:18 PM
Socalandy   Very cool   Mar 9 2012, 08:47 PM
effutuo101   There is an adhesive that has to go on bare metal ...   Mar 10 2012, 07:21 AM
PeeGreen 914   I don't recall what it's called. One of my...   Mar 10 2012, 11:19 AM
Gint   That's killer Chris! How ya doin?   Mar 10 2012, 01:46 PM
westtexass2k   Your car is looking good. It looks like my car has...   Mar 10 2012, 02:54 PM
effutuo101   Hiyas Gint! Good! Busy. How is Shar? Hope ...   Mar 10 2012, 05:07 PM
mrbubblehead   thanks for the info on the panel bond.....did you ...   Mar 10 2012, 05:42 PM
effutuo101   I didn't. But, once you have everything fitted...   Mar 10 2012, 07:10 PM
raw1298   I used the same stuff on my flares. Works great an...   Mar 10 2012, 07:53 PM
jcambo7   :drooley: Need more pics... :poke: :D   Mar 10 2012, 07:56 PM
effutuo101   I used the same stuff on my flares. Works great a...   Mar 11 2012, 04:17 PM
effutuo101   Refitting intakes yesterday. Just a couple of mino...   Mar 13 2012, 10:15 AM
jcambo7   Refitting intakes yesterday. Just a couple of min...   Mar 13 2012, 10:37 AM
effutuo101   Rear deck fitted, naca ducts finalizes, roof 99.9%...   Mar 14 2012, 09:20 PM
dlo914   I think you just convinced me that my next 914 has...   Mar 15 2012, 03:36 AM
effutuo101   As long as she has legs a little bit of bedunkedun...   Mar 15 2012, 08:48 AM
jcambo7   :ttiwwp: I cant reed i need picurs...:beer3:   Mar 15 2012, 09:51 AM
effutuo101   Ok James! didn't get much done today due ...   Mar 18 2012, 07:17 PM
effutuo101   oh, and saw this at work   Mar 18 2012, 07:18 PM
effutuo101   hope to get more done tomorrow.   Mar 18 2012, 07:18 PM
PeeGreen 914   The Fiskar looks really cool. I just hope the issu...   Mar 18 2012, 08:05 PM
effutuo101   Makes two of us. very pretty car. anyways onwards...   Mar 20 2012, 04:00 PM
jcambo7   :drooley:   Mar 21 2012, 09:08 AM
effutuo101   hood pins and mirrors showed up... I guess I will ...   Mar 23 2012, 05:59 PM
pete-stevers   where did you get those hood pins from??   Mar 23 2012, 08:12 PM
dakotaewing   What kind of mirrors?   Mar 23 2012, 09:13 PM
effutuo101   I got them bot from "dreamers" (local ho...   Mar 23 2012, 10:42 PM
effutuo101   The mirrors are Vision out of Canada. VF4 http://v...   Mar 24 2012, 09:18 AM
effutuo101   hood pins are Eddie Motorsports. they come in a te...   Mar 26 2012, 09:43 AM
jcambo7   Ooo...A GT lid. Are you putting it on this 914? :...   Mar 26 2012, 09:47 AM
effutuo101   LOL! Hi James, I am going to have options....w...   Mar 26 2012, 10:11 AM
effutuo101   so, I did it. I cut apart my dash last night and l...   Mar 27 2012, 12:08 PM
PeeGreen 914   Hey Chris, You should make two of those :poke: :...   Mar 27 2012, 04:49 PM
effutuo101   LOL! If you know somebody who can make a mold,...   Mar 27 2012, 06:05 PM
McMark   Cool stuff! :shades2:   Mar 27 2012, 06:14 PM
effutuo101   on a con call since 5 am. So, I built and test fit...   Mar 30 2012, 03:00 PM
effutuo101   an now for a picture... pre wax and final prep for...   Mar 30 2012, 03:01 PM
effutuo101   yes, it is a mail box...:) but once I get the glas...   Mar 30 2012, 03:02 PM
jcambo7   :popcorn:   Mar 30 2012, 03:04 PM
effutuo101   The wife had oral surgery Thursday afternoon. She ...   Mar 31 2012, 06:05 PM
sixnotfour   Wish Her Well.. should I come over tomorrow ?   Mar 31 2012, 06:48 PM
effutuo101   Sounds good! :toke:   Mar 31 2012, 07:16 PM
NORD   Make that Gloove Box big enough to hold all the Ti...   Mar 31 2012, 09:17 PM
Ductech   Dood .....'did your engine mount and trans sho...   Apr 1 2012, 12:19 AM
effutuo101   Hi Nord! yes, it has come a long way. The help...   Apr 1 2012, 08:12 AM
effutuo101   So, late last night, I popped the glove box off th...   Apr 1 2012, 08:14 AM
effutuo101   a little trimming up and presto, a glove box. @ ...   Apr 1 2012, 08:16 AM
effutuo101   got the headlight switch and dimmer switch cut out...   Apr 1 2012, 08:17 AM
effutuo101   this morning: Drink coffee later today maybe: dr...   Apr 1 2012, 08:20 AM
MDG   Diggin' it! :thumbsup:   Apr 1 2012, 08:21 AM
effutuo101   an oddly strange day at work. Took my lunch hour a...   Apr 2 2012, 05:57 PM
mrbubblehead   good work. you are going to have a real nice car.   Apr 2 2012, 06:40 PM
effutuo101   Thanks! It is coming to a town near you at the...   Apr 2 2012, 09:23 PM
effutuo101   the column is out of a 2002 VW beetle. We should b...   Apr 2 2012, 09:25 PM
effutuo101   start mirrors   Apr 9 2012, 04:33 PM
effutuo101   lunch time work... :stir:   Apr 9 2012, 04:35 PM
effutuo101   not much posting, but some progress picked up my c...   Apr 23 2012, 01:04 PM
IM101   not much posting, but some progress picked up my ...   Apr 24 2012, 01:27 PM
sixnotfour   Where is the blood pool picture from your 914 cutt...   Apr 23 2012, 10:21 PM
sixnotfour   Doesn't your cowl look more like this now ??   Apr 23 2012, 10:32 PM
effutuo101   Not yet, got the grinding done yesterday. primer a...   Apr 24 2012, 08:52 AM
ruby914   Looking good Chris. Nice cradle, hats off to Ian f...   Apr 24 2012, 10:37 AM
effutuo101   Thanks, No, not a suby cluster. gauge cluster on w...   Apr 24 2012, 11:33 AM
effutuo101   so far the steering will go closer to the dash tha...   Apr 24 2012, 11:35 AM
5 Pages V  1 2 3 > »
35 User(s) are reading this topic (35 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 23rd November 2024 - 04:48 PM
