Effutuo build, Ok, enough brow beating. here you go... |
effutuo101 |
Mar 9 2012, 10:44 AM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
(IMG:style_emoticons/default/dry.gif)
So, last year I picked up Ugmo. After a short stint, Rich D. came up with this car. As it already had a lot of what I wanted to do to my ride, I talked to Rich and we traded off Ugmo. Let the cutting and welding begin. We would need: new floors welded in cut off the remaining fenders GT kit welded in Media blast primer The eventual build would have Fiberglass fenders, hoods, rear bumper suby motor Low maintenance easy for the wiffy to drive Lets begin Attached image(s) |
effutuo101 |
Mar 9 2012, 12:38 PM
@ Ferg! (IMG:style_emoticons/default/pray.gif)
any new projects? @ goth. spray lizard skin first. then put on matting. it must be sprayed on primer or paint. Jeggs has it cheap. the gun is really cheap. Also, for what you are doing, you might want to find somebody to go in with you and share the product. It comes in 2 gallon containers. |
gothspeed |
Mar 9 2012, 03:44 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
................. @ goth. spray lizard skin first. then put on matting. it must be sprayed on primer or paint. Jeggs has it cheap. the gun is really cheap. Also, for what you are doing, you might want to find somebody to go in with you and share the product. It comes in 2 gallon containers. Ok so the lizard skin must go on pretty smooth then? ........ if so, what you recommend sounds like a good aproach ..... the deadener mat I will be using is the damplifier pro ................ thanks man!! (IMG:style_emoticons/default/beerchug.gif) |
effutuo101 |
Mar 9 2012, 06:55 PM
................. @ goth. spray lizard skin first. then put on matting. it must be sprayed on primer or paint. Jeggs has it cheap. the gun is really cheap. Also, for what you are doing, you might want to find somebody to go in with you and share the product. It comes in 2 gallon containers. Ok so the lizard skin must go on pretty smooth then? ........ if so, what you recommend sounds like a good aproach ..... the deadener mat I will be using is the damplifier pro ................ thanks man!! (IMG:style_emoticons/default/beerchug.gif) Not really. It depends on how you adjust the fun. It goes on a lot like Rhino with a serious texture. Not smooth like paint. More like a textured wall in your house. |
Lo-Fi Version | Time is now: 23rd November 2024 - 05:08 PM |
