2.0 Djet problem, Will not take gas. Idles fine |
benalishhero |
Mar 15 2012, 01:09 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Hey guys, I thought I'd pick your brains on this one. If you could knock some ideas around that would be great. I'm stuck on this one.
First off, all the baseline stuff is in order. e.g. valves, ignition, fuel pressure, vacuum etc.. The motor starts fine cold or warm, and idles fine. However it will not take gas off a stop. It will go with about 1/4 throttle if I feather it. If I punch it immediately it dies. I can also, if up to a fair speed, full throttle it(through the bog) and back it off just a bit and it will take off. Basically it's fine at idle and at full enrich. I'm suspecting a dead-spot in the TPS. (IMG:style_emoticons/default/confused24.gif). Can a bad CHT cause poor acceleration? Enjoy the day Thomas |
underthetire |
Mar 15 2012, 02:03 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Stuck advance in the Dizzy?
benalishhero |
Mar 15 2012, 02:07 PM
914_teener |
Mar 15 2012, 02:17 PM
914 Guru Group: Members Posts: 5,245 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
benalishhero |
Mar 15 2012, 02:30 PM
Try swapping out to a known working ECU to elimate it. I was thinking that. Now where to find one in Maine (IMG:style_emoticons/default/idea.gif) ? |
Lo-Fi Version | Time is now: 27th September 2024 - 06:33 AM |
