intake tube alignment, 3/4 tube to the distributor is off |
malcolm2 |
Mar 21 2012, 06:44 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Well, I did not pay enough attention as I was taking this engine apart. I cleaned, blasted and painted the intake tubes and the "intake distributor" (please correct me if I have mis-named). Anyway, I am a good 1/4" off center on the #3 cylinder intake tube, left tube. This can't be good or right, can it? I can get the short rubber hose on,
this kind of offset will leak right? the 1/2 side lines up nicely |
Valy |
Mar 21 2012, 07:18 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Looking at the pictures again, I see 2.0 runners and 1.8 box.
If you replace the heads to 3 studs, just drill the 1.8 runners. |
02loftsmoor |
Mar 21 2012, 07:39 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
malcolm2 |
Mar 21 2012, 07:42 PM
From your posts you seem to be in the know. Question, would it be worth while to polish and match the intake system? Thanks Wes Looking at the pictures again, I see 2.0 runners and 1.8 box. If you replace the heads to 3 studs, just drill the 1.8 runners. But he thinks I would put a 3 hole tube on a 4 stud head and not notice? (IMG:style_emoticons/default/shades.gif) |
malcolm2 |
Mar 21 2012, 09:09 PM
Lo-Fi Version | Time is now: 27th September 2024 - 02:17 PM |
