Wheel stud dimensions - machinig question, Eric shea? Brad? |
Aaron Cox |
May 18 2004, 07:11 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
hey guys, what is the final hole size that is needed to be drilled for the press in wheel studs in the hub? also, what is the size of the most rear part of the stud (the size i need to spotface)
thanks guys! |
Mueller |
May 27 2004, 10:50 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Hey Eric, so have you pressed in the Verbus studs yet using the 14mm thru hole?
Is 14mm the magic number or should it be larger? (cannot be smaller size it would be a little hard getting the threaded portion thru the hub, LOL) Have you put a straight edge over the surface with the new studs pressed in? I've read that the hub surface can get distorted if the thru hole is too small and/or a small chamfer was not added to the thru holes before the stud is installed. I'm keeping my car 4-lug, but I am converting it to studs instead of bolts since I am going to run a 12mm spacer in the rear and and a 25mm spacer in the front (both front and rear spacers will be hubcentric) |
Lo-Fi Version | Time is now: 27th September 2024 - 08:56 AM |
