what's the story with this steering wheel, #914 347 805 10 |
rhodyguy |
May 29 2012, 01:16 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the back side of the center is weird and there is a little spring with non ferrous contact point on the inside end coming out the front of the center portion. then i found another one with the # 914 347 805 11. wasup?
k Attached image(s) |
rhodyguy |
May 29 2012, 01:52 PM
back shot. there are no threaded holes to attach anything to. there are 6 small threaded holes in the center section.
Gustl |
May 29 2012, 03:22 PM
914 enthusiast & historian Group: Members Posts: 11,618 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
back shot. there are no threaded holes to attach anything to. there are 6 small threaded holes in the center section. as you learned above, this is a 1970/71 leather steering wheel for the 914-4 therefore you need to attach this black thing (sorry ... don't know its name): and there are 4 little screws to mount it on the steering wheel - I put red circles around the mounting holes: when using it this way, the horn contact is made with the little brown cable when using it on a 914-6 you will need the horn contact with the spring (as shown in your post); but ... originally it should look like this: |
Lo-Fi Version | Time is now: 27th September 2024 - 09:52 AM |
