Falls into the "sounds like BS" catagory..., I shit you not..... |
SpecialK |
May 30 2004, 12:34 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Okay, I picked up the '74 from the owner in Downers Grove, IL (also the hometown of Denise Richards [hottie!! (IMG:style_emoticons/default/wub.gif) ]). We got a room at the Holiday Inn down the road, dropped off the 914, and took the wifes Cherokee to Chicago to check out the sites. All I can say is downtown Chicago is pictured in the dictionary under the word "ClusterF*ck" (IMG:style_emoticons/default/wacko.gif) !!
The car fired right up, farted, burped and smoothed out with its stock FI (IMG:style_emoticons/default/biggrin.gif) . It pulls hard, handles fantastic, sounds great and with the exception of a crack in the dash, the interior is perfect!! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) The fuel gauge wasn't working so I topped off the tank prior to hitting the highway because I had no idea what kind of mpg to expect, and didn't want any surprises. Got on at exit #267, I-55 south and ended up refueling a exit #154. The little bastard wouldn't take more than 2.4 gal. (IMG:style_emoticons/default/ohmy.gif) , stuck my head in the trunk to get a visual on the fuel level, and sure enough it was full (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/ohmy.gif) . 47 MPG!! NFW!! Didn't put much faith in that estimate, but figured with a full tank I should easily make it home without a refill. Back on the road, drove it straight home 35 miles SW of St. Louis...154 + 35 = 189 miles...filled it up again when I got into Pacific (home) and had only used 3.75 gal (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/ohmy.gif) 50.4 MPG!! again, NFW!!...stuck my head back in the trunk, and sure enough, tank was full!! I shit you NOT... |
Toast |
May 30 2004, 12:49 PM
Not bad for carrying sway bars. Group: Members Posts: 3,380 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
You Suck!
(IMG:style_emoticons/default/finger.gif) Just kidding. If that is really the case, you are a lucky man. I'll be damned if I dont have to refill at $2.50+ a gallon every time I go to the store and back. (Ok, that may be a bit extreme, but seems like it sometimes.) (IMG:style_emoticons/default/wacko.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 08:18 AM |
