Falls into the "sounds like BS" catagory..., I shit you not..... |
SpecialK |
May 30 2004, 12:34 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Okay, I picked up the '74 from the owner in Downers Grove, IL (also the hometown of Denise Richards [hottie!! (IMG:style_emoticons/default/wub.gif) ]). We got a room at the Holiday Inn down the road, dropped off the 914, and took the wifes Cherokee to Chicago to check out the sites. All I can say is downtown Chicago is pictured in the dictionary under the word "ClusterF*ck" (IMG:style_emoticons/default/wacko.gif) !!
The car fired right up, farted, burped and smoothed out with its stock FI (IMG:style_emoticons/default/biggrin.gif) . It pulls hard, handles fantastic, sounds great and with the exception of a crack in the dash, the interior is perfect!! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) The fuel gauge wasn't working so I topped off the tank prior to hitting the highway because I had no idea what kind of mpg to expect, and didn't want any surprises. Got on at exit #267, I-55 south and ended up refueling a exit #154. The little bastard wouldn't take more than 2.4 gal. (IMG:style_emoticons/default/ohmy.gif) , stuck my head in the trunk to get a visual on the fuel level, and sure enough it was full (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/ohmy.gif) . 47 MPG!! NFW!! Didn't put much faith in that estimate, but figured with a full tank I should easily make it home without a refill. Back on the road, drove it straight home 35 miles SW of St. Louis...154 + 35 = 189 miles...filled it up again when I got into Pacific (home) and had only used 3.75 gal (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/ohmy.gif) 50.4 MPG!! again, NFW!!...stuck my head back in the trunk, and sure enough, tank was full!! I shit you NOT... |
SpecialK |
May 30 2004, 01:04 PM
I still need to do the once over on the engine (points, plugs, filters, oil etc.), clean up some corrosion on the lightbulb sockets, and figure out what's up with the fuel gauge. Other than that I think it's ready for the safety inspection and plates (IMG:style_emoticons/default/smilie_pokal.gif)
I definitely want to take a look at the plugs to make sure it's not running so lean it's going to have a meltdown. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:19 AM |
