GT rockers to GT flare, Reshaping rockers, what looks best, need photos. |
ruby914 |
Jul 4 2012, 03:28 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I got some budget rockers that (IMG:style_emoticons/default/barf.gif) needed lots of work.
First cut about 1" off the top and had to add 3/4" to the bottom. Cut about 1/4 off the front but I still don't like how it flares out different than the body lines. On the bottom of the door there is a bevel in the body that the rocker follows until it flares out. At that point the rocker flares as much as the body, not staying set in as much as the bevel. I am thinking it would look better If the rocker didn't flare out so much. Is that clear? I would like to see how others have handled this trasition. Attached image(s) |
RON S. |
Jul 5 2012, 12:35 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Can I jump in here to say... Sweet car, Ron S. (IMG:style_emoticons/default/beerchug.gif) and Is the silver on the bumpers paint or some other product? The bumpers were just painted with a semi-gloss black on the tops, and gloss silver enamel on the bottoms. Yes, that's a very nice car Ron. Nice work. I did see someone section out the bottoms of the flares, maybe it was you. It's still not too late for me to do the same, I like the look. Are your rockers Getty Design? My thinking was, if they all fit like (IMG:style_emoticons/default/stromberg.gif) just get the cheap ones and make them work. I am sure it helps with a good rocker to start with. I did most all of the fit work on the flare bottoms. The rockers had a some what flat edge to them so I made the flares to match the rockers. The front spoiler, rear valance and the rocker panels were all AIR products. The front spoiler and the rear valance were heavily sectioned then bolted to the car, then re fiber glassed while in place to form to the car. Doing this removes the stresses on the panel when locked down and in operation. No worries about cracks or broken mounting ears after years of road use. The rockers were pretty much a bolt on only. They were bought for 11'' wide rear flares, so again when I fit the rear flares I made the ends match the rear end of the rockers. My flares were AA flairs also. They were a really good product to work with. They key is to take your time and get it looking the way it needs to look before you shoot the paint. Ron Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 23rd November 2024 - 01:30 AM |
