Think I need an external oil cooler..., who makes the best kit? |
billh1963 |
Jul 18 2012, 12:49 PM
Car Hoarder! Group: Members Posts: 3,403 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Driving one of the cars (2.0L with dual carbs) and see a consistent 230-240F on the dipstick temp gauge. The gauge is accurate (tested in boiling water). Normal driving.... 90F day, mixed speeds with 60 to 70 mph max, flat terrain.
The PO had pulled the tins to repaint them so I assume mice nests are not a problem. I will check the oil cooler and the bellows this weekend; however, I don't expect any issues there. So, other than investigating to see if there is a lean condition with the carbs (which impacts CHT more than oil temp...correct?), It looks like my options for remediation are limited to an oil cooler. I've done a search and find most threads are for 6 conversions or homemade setups. Of the few kits available, is there any consensus on a good affordable solution? |
mrbubblehead |
Jul 19 2012, 10:22 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i believe 212 is considered normal operating temperature for engine oil. thats the number i shoot for. and 10 psi per 1000 rpm at operating temp.
Lo-Fi Version | Time is now: 27th September 2024 - 12:08 PM |
