Think I need an external oil cooler..., who makes the best kit? |
billh1963 |
Jul 18 2012, 12:49 PM
Car Hoarder! Group: Members Posts: 3,403 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Driving one of the cars (2.0L with dual carbs) and see a consistent 230-240F on the dipstick temp gauge. The gauge is accurate (tested in boiling water). Normal driving.... 90F day, mixed speeds with 60 to 70 mph max, flat terrain.
The PO had pulled the tins to repaint them so I assume mice nests are not a problem. I will check the oil cooler and the bellows this weekend; however, I don't expect any issues there. So, other than investigating to see if there is a lean condition with the carbs (which impacts CHT more than oil temp...correct?), It looks like my options for remediation are limited to an oil cooler. I've done a search and find most threads are for 6 conversions or homemade setups. Of the few kits available, is there any consensus on a good affordable solution? |
Dr Evil |
Jul 19 2012, 11:35 PM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
If you run at 180 you never get all of the moisture out of the oil and it begins to make that nasty butter. I am in the 212 camp, too.
rwilner |
Jul 20 2012, 07:41 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
no one mentioned timing, I know this can have a major effect on cyl head temps...not sure about oil temps. Worth checking methinks.
Lo-Fi Version | Time is now: 27th September 2024 - 12:02 PM |
