Think I need an external oil cooler..., who makes the best kit? |
billh1963 |
Jul 18 2012, 12:49 PM
Car Hoarder! Group: Members Posts: 3,403 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Driving one of the cars (2.0L with dual carbs) and see a consistent 230-240F on the dipstick temp gauge. The gauge is accurate (tested in boiling water). Normal driving.... 90F day, mixed speeds with 60 to 70 mph max, flat terrain.
The PO had pulled the tins to repaint them so I assume mice nests are not a problem. I will check the oil cooler and the bellows this weekend; however, I don't expect any issues there. So, other than investigating to see if there is a lean condition with the carbs (which impacts CHT more than oil temp...correct?), It looks like my options for remediation are limited to an oil cooler. I've done a search and find most threads are for 6 conversions or homemade setups. Of the few kits available, is there any consensus on a good affordable solution? |
ape914 |
Jul 23 2012, 11:00 AM
red locktite Group: Retired Members Posts: 240 Joined: 7-February 11 From: In front of a computer Member No.: 12,676 Region Association: None |
flex dam, is that a front air dam? how do you reckon it causes high temps? I'd be thinking it would help reduce the air pressure under the car and thus aid in engine cooling air flow. That is just my assumption, how do you figure it causes higher temps? I must not be thinking about it right.
Lo-Fi Version | Time is now: 27th September 2024 - 12:04 PM |
