Proportioning valve needed for LS1 conversion? |
mittelmotor |
Jul 24 2012, 12:32 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Renegade Hybrids suggests doing away with the rear proportioning valve for their LS1 V-8 conversion, and replacing it with a T fitting. I know in stock configuration this could increase the likelihood of rear lockup. My car has the stock MC, stock 914-4 rear brakes and 911 "M" calipers & vented rotors up front. It'll also have a bit of tire stagger, 205s in front and 225s in rear. Will a T fitting be OK with this setup? Thanks!
yeahmag |
Jul 27 2012, 05:31 PM
Advanced Member Group: Members Posts: 2,435 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Depending on your driving style the 21mm front torsions may dictate a heavier rear spring. With 21mm torsions and Koni Yellow's all around I moved from 180 -> 225 -> and now will be trying 300's in the rear.
Lo-Fi Version | Time is now: 27th September 2024 - 12:20 PM |
