little electrical gremlins, NEED HELP |
Strudelwagon |
Aug 17 2012, 05:34 PM
Member Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada |
So my 3 year project is on the road...first 914 i have ever owned so maybe this is normal???
when I put my turn signal on (74-2.0) the little green light on the tach flashes. when it self cancels, sometimes the green light stays on steady. If I move the signal lever a little it goes off??? just the little light not the actual signal lights on the corners any idea? (IMG:style_emoticons/default/confused24.gif) SW |
Mike Bellis |
Sep 7 2012, 10:40 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Could be a bad flasher relay too. The flasher relay is a dual semi-electronic relay. It has one relay dedicated to the exterior lamps and one for the dash lamp. It is possible for half the relay to go bad. Relay failure can be accelerated by adding LED lamps to the turn signals. Replacement relays are available for around $50. Plug and play.
Lo-Fi Version | Time is now: 27th September 2024 - 09:23 AM |
