Too Much Heat~!, Not the Engine the Cabin |
914werke |
Sep 12 2012, 11:09 AM
"I got blisters on me fingers" Group: Members Posts: 10,542 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So after resurrecting the Phoenix Ive been attempting to expel a few remaining demons (IMG:style_emoticons/default/biggrin.gif)
A couple are clearly FI & electrical, a couple others are simple mechanical issues that will just take time/patience to correct... But one that is somewhat annoying me and sort of surprising is that IVE GOT TO MUCH HEAT! The car runs right in spec temp-wise but the heat generated by the HE's is bleeding into the cabin to the point that it is uncomfortable especially in our warm summer days here in the PNW (IMG:style_emoticons/default/sad.gif) What can I do? I was planning on replacing/renewing the "sealing" material on the flap in each heater box, is part of the problem that the foam seals in the fresh air box valves also shot ? (IMG:style_emoticons/default/headbang.gif) I dread ripping that setup apart again! (IMG:style_emoticons/default/smash.gif) |
brant |
Sep 12 2012, 11:52 AM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
sometimes the cable on the flapper boxes gets attatched in such a way as to limit their ability to close fully.
I used to crawl under the car and loosen the cable every summer and then tighten it every fall once its loose it won't pull them 100% open so you are giving up a tiny bit of heat, but at least it closes fully brant |
Lo-Fi Version | Time is now: 26th September 2024 - 11:15 PM |
