Too Much Heat~!, Not the Engine the Cabin |
914werke |
Sep 12 2012, 11:09 AM
"I got blisters on me fingers" Group: Members Posts: 10,542 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So after resurrecting the Phoenix Ive been attempting to expel a few remaining demons (IMG:style_emoticons/default/biggrin.gif)
A couple are clearly FI & electrical, a couple others are simple mechanical issues that will just take time/patience to correct... But one that is somewhat annoying me and sort of surprising is that IVE GOT TO MUCH HEAT! The car runs right in spec temp-wise but the heat generated by the HE's is bleeding into the cabin to the point that it is uncomfortable especially in our warm summer days here in the PNW (IMG:style_emoticons/default/sad.gif) What can I do? I was planning on replacing/renewing the "sealing" material on the flap in each heater box, is part of the problem that the foam seals in the fresh air box valves also shot ? (IMG:style_emoticons/default/headbang.gif) I dread ripping that setup apart again! (IMG:style_emoticons/default/smash.gif) |
mrbubblehead |
Sep 12 2012, 10:21 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
mine had a loose nut that had fallen in there and was holding the flapper open.
Lo-Fi Version | Time is now: 26th September 2024 - 11:21 PM |
