What is carburetor percolation..., How can I take care of this annoying problem |
nsr-jamie |
Nov 5 2012, 08:31 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Hi, over here in Japan where it is much hotter and humid than the rest of most parts of the world. My car is a 1972 914-4 model that has been tuned up a bit with 103mm p/c, high can and big valve heads (48x38) and twin 40mm drla Dellorto carbs....in the summer time the car seems to run badly and when I stop the car for even a short time to run into the 7-11 and try to restart the 914 it sometimes is quite difficult to get it running again. I talked with my mechanic friend at my local air cooled VW shop here and he told me I was experiencing carburetor percolation which seems to be common on these cars or air cooled engines that are running carbs like mine. I did a bit of research and found nothing here on this site but a little bit on google....not really sure what carburetor percolation is but kind of sounds like the carbs are over heating from the engine heat. Are others experiencing this problem too and if so what are you doing to try to fix it. My shop mentioned special gaskets or spacers to go in between the carbs and manifolds to cure this problem...it seems to occur more here on this side of the planet cause of the humid and hotter weather compared to say back home in the US or Europe. I checked on the CB Performance site and could not find spacers.....any body have any input to add? Thanks and cheers
Jamie in Japan |
nsr-jamie |
Nov 6 2012, 09:29 AM
Hello everyone and thank you for the excellent replies. Spacers sound like the way to go and now that my engine is now out of the car I have decided to try to rebuild the carbs myself...I saw the spacers on Ebay (thanks McMark) and I think I might be able to make them myself on the CNC mill at work in my free time. It seems like the material I need is called phenolic and I did a quick search and "BakeLite" was also mentioned. We actually have some bakelite at work that has been sitting for years that I could use and try to attempt to make a set of these spacers. It might be kind of fun to try and make them and see how they turn out.
Is this going to affect my linkage, the thickness of the material is 8mm....I guess I will need new stud bolts for the manifolds. This could be fun to try to make something like this....just wondering if I can machine or mill bakelite (phenolic), I guess I need to do more searching again on the web. I will let you guys know soon. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:23 PM |
