SOT: electrical gurus check in..., how to dim LEDs? |
dlo914 |
Nov 30 2012, 12:45 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
So i've retrofitted some LED rings into my daily driver, but i'm only using the LEDs as the running lights and using the filament bulb when brakes are applied. how would i go about using the LEDs for both running and braking light usage? i know i'm suppose to add a resistor to each positive LED wire, but i'm so confused as to what OHM rating or % etc i'm suppose to use. The guys at two radioshacks were useless.
Here's how they look at the moment: (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-2697-1354257938.1.jpg) |
Spoke |
Nov 30 2012, 08:26 AM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
For the brake light with higher intensity, as Tom said, use a lower value resistor.
To do this, you'll need to know how the unit is wired. Got a pic and/or model number of the unit? You want to use them as both brake lights and running lights. For the running lights, there are only 2 wires. For running lights and brake lights, you'll need 3 wires like the typical 1057 brake/running bulb. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:53 AM |
