Does anyone restore engine relay panels? |
shuie |
Dec 31 2012, 05:05 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
The engine relay panel for my '71 is garbage. Does anyone rebuild these or make something similar without all of the heater and window defogger stuff? I have removed all of the heater components from the car and stripped all of that wiring out of the harness. All I need is the power supply relay, fuel pump relay, and voltage regulator provision.
914Sixer |
Jan 1 2013, 09:19 PM
914 Guru Group: Members Posts: 8,989 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I can do a stock one for you. I will not be able to reproduce the thick tar but I can seal the bottom with a new product.
chads74 |
Jan 1 2013, 10:46 PM
Member Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States |
I can do a stock one for you. I will not be able to reproduce the thick tar but I can seal the bottom with a new product. I just noticed today that the tar is falling off of my replay board. What kind of product would you recommend me using to reseal the bottom? |
rfuerst911sc |
Jan 3 2013, 05:08 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I can do a stock one for you. I will not be able to reproduce the thick tar but I can seal the bottom with a new product. I just noticed today that the tar is falling off of my replay board. What kind of product would you recommend me using to reseal the bottom? The tar was cracking/falling off my relay board also. I removed the tar by carefully chipping away at it really wasn't that tough to do. I cleaned the bottom of the board with alcohol and a brush. Visually inspected the solder joints, all looked good so I sprayed black " Dip It " on the bottom of the board. This is sold in many box stores like Home Depot. Originally it was a liquid that you dipped tool handles into to make a rubber/vinyl hand grip. They then added an aerosol version. I sprayed about 4-5 layers it does not build to a thickness of the original but it is waterproof and flexible. It has been working for 4 + years with no issues. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:11 AM |
