> Hydraulic Clutch, This works GREAT!
PRS914-6
post Sep 1 2007, 10:29 PM
Excellence Magazine Project 914 3.6
Group: Retired Members
Seems like there is always interest in converting to a hydraulic clutch. Using a 911 clutch gives a bit of a stiff pedal but my biggest complaint was I didn't like the modulation and feel especially using a performance clutch disk. The 914-6 cable is much smaller in diameter than a 911 cable and aggravates the problem. In addition, my first gear is really tall and with a clutch that felt like it was on/off was a little annoying and down right scary when stopped on a hill with someone on my ass.
I picked up a new generic master cylinder and pull style slave (available at most any buggy shop for under $150.00 I also picked up a 4 ounce remote reservoir.
I made a plate that fit under the brake master cylinder and a bracket that fit on the side cover of my 915 tranny and ran the hydraulic lines down the tunnel. I also installed a bracket from the plate to the I beam of the suspension to eliminate any flex.
I'll cover the entire installation in a future issue of Excellence with the project car (at Pete's discretion) but here are a few pictures to show the method I used. The "feel" and modulation of the clutch is dramatically improved. Absolutely smooth as silk now.
IronHillRestorations
post Feb 25 2013, 01:43 PM
I. I. R. C.
I ran the hydraulic line through the clutch tube. The only issue I ran into was heat from the exhaust system cooking the seals in the slave cylinder. I made a heat shield and wrapped the heat exchangers.
PRS914-6   Hydraulic Clutch   Sep 1 2007, 10:29 PM
PRS914-6   And a few more...... And Ron S. This is for you...   Sep 1 2007, 10:33 PM
brp914   :thumbsup: That is something to be proud of. BTW,...   Sep 1 2007, 10:58 PM
PRS914-6   WEVO. I like it a lot. It shifts better and more...   Sep 1 2007, 11:05 PM
76-914   I know, I know. 3 demerits for bringing an old thr...   Feb 21 2013, 10:00 AM
KaptKaos   It is me or does that master cylinder seem to be i...   Feb 21 2013, 01:33 PM
URY914   The clutch pedal is on a shaft that passes thru th...   Feb 21 2013, 01:41 PM
biosurfer1   I'm sure Paul will be along shortly but I...   Feb 21 2013, 02:56 PM
396   If Paul would offer "kit" I'm in......   Feb 21 2013, 04:56 PM
PRS914-6   Here are a few pics that should help. You simply ...   Feb 21 2013, 05:11 PM
RonW   nicely done. subscribed.   Feb 21 2013, 05:14 PM
RON S.   Paul, Welcome to the hydraulic ...   Feb 21 2013, 05:34 PM
racerx9146   Larry hubby did a nice write up back in 2008 with ...   Feb 21 2013, 07:40 PM
GeorgeRud   Any info on the size of the master or slave cylind...   Feb 22 2013, 05:47 PM
9146986   In '95 I used a 928 clutch master cylinder and...   Feb 24 2013, 09:20 PM
PRS914-6   The sizes of the master and slave should be the sa...   Feb 24 2013, 09:36 PM
76-914   Paul, this is a great help. Thx again.   Feb 24 2013, 10:01 PM
dfelz   Hey Paul, whats the bore diam. of the master cylin...   Feb 24 2013, 10:57 PM
Dave_Darling   The exact diameter is not very important, just tha...   Feb 25 2013, 10:18 AM
dfelz   The exact diameter is not very important, just th...   Feb 25 2013, 02:38 PM
euro911   :idea:   Feb 25 2013, 01:11 PM
9146986   I ran the hydraulic line through the clutch tube. ...   Feb 25 2013, 01:43 PM
euro911   David, as long as ID is the same in both cylinders...   Feb 25 2013, 03:38 PM
Elliot Cannon   Well, that's just great! I get started on...   Feb 25 2013, 07:11 PM
76-914   Well, that's just great! I get started o...   Feb 26 2013, 08:53 AM
charliew   Good info and pictures. I like having two reservio...   Feb 26 2013, 10:47 AM
Mark Henry   Of course I'm looking to do this with cheaper ...   Feb 26 2013, 10:58 AM
skeates   I'm curious how the clutch pedal was modified ...   Feb 28 2013, 03:52 PM
PRS914-6   I'm curious how the clutch pedal was modified...   Feb 28 2013, 04:08 PM
skeates   I'm curious how the clutch pedal was modifie...   Mar 1 2013, 05:01 PM
02loftsmoor   do realize your though out bearing will be always ...   Mar 2 2013, 03:23 PM
Dave_Darling   The stock one is as well. So? --DD   Mar 2 2013, 07:22 PM
tscrihfield   Resurrecting this thread because it is awesome. P...   Aug 27 2021, 09:56 AM
strawman   On my Suby-swapped 914, I'm using a Honda Civi...   Aug 27 2021, 11:42 AM
- Lo-Fi Version Time is now: 23rd November 2024 - 07:01 AM
