Headlight motor, electrical problem? |
EJP914 |
Feb 28 2010, 07:15 PM
Member Group: Members Posts: 262 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
I am reinstalling the headlights, brackets, pivots, etc after having the car repainted. All works well on the RH side. Headlight lights up and it opens and closes. On the LH side the headlight lights up in the closed position. It will not open and close. I have replaced the relay with one I know is good. The ground wire is tight. No blown fuses in the fuse panel. The nut that holds the lever to the splined post on the motor seems tight enough. If I manually turn the black knob at the back of the motor, the light will cycle open and then close.
Electrical problem somewhere? What do the 3 wires do that plug into the 3 wire plug coming from the motor? Red = power? Does this wire give power to the motor AND the headlight? Green??? Gray??? I thought headlight motors were pretty much bulletproof, last forever. Maybe not. If anyone has a suggestion on how to attack this problem and what I should look at first, please let me know. . Thanks in advance for the advice. |
southernmost914 |
Feb 28 2010, 07:52 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
I am reinstalling the headlights, brackets, pivots, etc after having the car repainted. All works well on the RH side. Headlight lights up and it opens and closes. On the LH side the headlight lights up in the closed position. It will not open and close. I have replaced the relay with one I know is good. The ground wire is tight. No blown fuses in the fuse panel. The nut that holds the lever to the splined post on the motor seems tight enough. If I manually turn the black knob at the back of the motor, the light will cycle open and then close. Electrical problem somewhere? What do the 3 wires do that plug into the 3 wire plug coming from the motor? Red = power? Does this wire give power to the motor AND the headlight? Green??? Gray??? I thought headlight motors were pretty much bulletproof, last forever. Maybe not. If anyone has a suggestion on how to attack this problem and what I should look at first, please let me know. . Thanks in advance for the advice. When you manualy cycle the head light with the black knob does it take over and go through its cycle? If so bad headlight switch . If not bad motor or connections to motor. (IMG:style_emoticons/default/biggrin.gif) |
7TPorsh |
Feb 27 2013, 01:19 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
When you manualy cycle the head light with the black knob does it take over and go through its cycle? If so bad headlight switch . If not bad motor or connections to motor. (IMG:style_emoticons/default/biggrin.gif) Old thread from search...I am experiencing this on the driver side; passenger side works fine. The motor does take over when I turn the knob. Is it really a switch issue? |
Lo-Fi Version | Time is now: 27th September 2024 - 01:13 AM |
