Relation between bad spark connection and lower compression? |
john_g |
Apr 6 2013, 07:02 PM
Member Group: Members Posts: 110 Joined: 1-November 12 From: british columbia Member No.: 15,100 Region Association: Canada |
Hey, guys, I'm curious about an interesting coincidence. My latest 914 is relatively new to me. When I purchased it, I noticed that it missed significantly at higher revs, especially in the lower gears. The owner said that it there was a rev limiter in the electronic ignition, but I knew that was BS because I removed the dizzie cap and saw that it had the normal rotor w/o the rev limiter, and also because I never ran it even close to the red line. The other issue I noted was that the #3 cylinder's compression was significantly lower than the other cylinders, but of course I assumed these two issues were unrelated.
When I got it home I found that the spark wire connection at the distributor cap for the #3 cylinder was very poor. As soon as I replaced the spark wires the problem of the engine missing stopped. This has got me thinking. Obviously, from what the PO said, the missing (and the bad spark connection at #3) had been going on for a while. Is it possible that running the car for a long time w/ poor spark at one cylinder could lower compression, through incomplete combustion, unburned gas, etc? And ... if the cylinder and valves are gummed up from this, could I expect that the compression could increase after some lengthy drives and cleaner combustion? |
flash914 |
Apr 6 2013, 11:18 PM
Member Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California |
Yes and No. The term is ring wash. If the unburnt gas end up diluting the oil on the cylinders it becomes metal to metal and the rings/ cylinders go away. A miss like this or a over rich carb can also cause this. Give it some time and it may come back around or? Gordon
Lo-Fi Version | Time is now: 27th September 2024 - 10:30 AM |
