Spring Identification, how's it done |
76-914 |
Mar 24 2013, 09:26 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
As revealed earlier, I don't know (IMG:style_emoticons/default/stromberg.gif) about suspension. I did know enough to listen to the pros and have taken Eric's set up advice. (guess who has new Bilsteins coming (IMG:style_emoticons/default/biggrin.gif) ) My question is this; how do I identify what I currently have? Is this done by the number of coils? Is it stamped somewhere? Color coded? Here is a shot of mine. And...what does 100,120,140lb represent? What happens at a given value? TIA, kent
Dave_Darling |
Apr 6 2013, 09:03 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Most of the aftermarket springs have a shorter free length than the space for them at full droop. I zip-tied the springs to the upper perches to keep them pointed the right way. And when I jack the car up, I check the spring position as I let it down to make sure the springs sit on the perches.
--DD |
76-914 |
Apr 7 2013, 07:34 AM
Most of the aftermarket springs have a shorter free length than the space for them at full droop. I zip-tied the springs to the upper perches to keep them pointed the right way. And when I jack the car up, I check the spring position as I let it down to make sure the springs sit on the perches. --DD Ah hah! Mystery solved. The ass end is so high it looks like an Alley Cat in heat. I'll lower it and use your method. Thx, Dave. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:24 AM |
