Growling sound from right rear., What could be causing it? |
FourBlades |
Apr 15 2013, 08:55 AM
From Wreck to Rockin Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
George and his friend Marc and I have been working on George's Chump Car.
We have made a lot of progress we need to post. One problem is a pretty loud growling coming from the right rear. It gets louder and softer with changes in speed. I pulled the caliper last night and the pistons were defintely stuck. I was able to free the inside but the outside is buggered. The caliper was gripping tight enough I could barely get it off the rotor. I plan to swap in a caliper from another car tonight and see what happens. We are trying to go to a DE this coming weekend so we don't have a ton of time. What else could be causing the problem? The wheel is very stable when grabbing it and wiggling it back and forth. If the bearing is going bad, would it cause the wheel to wobble noticeably? We also suspect it could be the CV. Any thoughts about the situation (other than it sucks)? John |
ThePaintedMan |
Apr 15 2013, 09:22 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
(IMG:style_emoticons/default/headbang.gif) Thought I had most of the problems figured out, but this is one that I hadn't sorted out before I brought the car to John.
As John said, its a deep growling sound. Other information that might be of help: 1) When I replaced the trailing arm bushings, I also adjusted the venting clearance, but had a hard time getting them setup to spec. I knew the brakes would have to be sent to Eric sooner or later. However, now that John mentioned the pistons being stuck, it makes more sense why I was having issues. 2) The tires are brand new, and the noise was the same as the previous set. 3) The CVs were recently checked, cleaned and repacked. No "clunking" when going around turns. 4) Bearings, as John said, do not appear to have any axial play. 5) No significant vibrations or imbalance. (Right John?) |
Lo-Fi Version | Time is now: 27th September 2024 - 06:43 AM |
