Rear wheel horsepower, How much should I have |
porschefile2010 |
Apr 24 2013, 01:41 AM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
So, we finally have the rebuilt engine back in the car and we decided to tune it on a "rolling road" to make sure we got the mixture right.
So this is a 75 2.0 with standard FI and no emmissions gear on it. I had sort of hoped for around 75hp at the wheels but it has come out at 57hp rwhp. Engine has new AA pistons and cylinders and the standard 2.0 heads so does this sort of number sound right and if it's way short what could be the problem. Also, will it get better as the new pistons settle in. I go get the car on Friday so will put some pics up then |
bulitt |
Apr 25 2013, 05:52 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
So, we finally have the rebuilt engine back in the car and we decided to tune it on a "rolling road" to make sure we got the mixture right. So this is a 75 2.0 with standard FI and no emmissions gear on it. I had sort of hoped for around 75hp at the wheels but it has come out at 57hp rwhp. Engine has new AA pistons and cylinders and the standard 2.0 heads so does this sort of number sound right and if it's way short what could be the problem. Also, will it get better as the new pistons settle in. I go get the car on Friday so will put some pics up then So they tuned the car on the dyno for you? Did they use a wideband O2 sensor to determine the A/F ratio? Did they use different plugs as they adjusted the ratio? Did they tweak the timing? What is the condition of your clutch? New? Slipping? What injectors are you using? |
Lo-Fi Version | Time is now: 27th September 2024 - 12:38 PM |
