Carb question, need to dump little gas in carb just to get car started |
angerosa |
Apr 28 2013, 08:45 AM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
Seems that this year I need to put a little gas into the carb to get the car started initially. I have single Solex carb that no one seems to be able to identify. I'm sure some PO just pulled it off something that was sitting in a junkyard. Once I get car started and it warms up it idles OK but runs rough when you try to drive it. Timing is spot on. Recent (not too many miles ago) tune up with the help of some very knowledgeable 914world brethren. Let’s say it’s a given that there is nothing wrong with the engine. I have an idea of where to go next. I’ve had car for about 7 years. With only what I’ve told you here what’s your opinion?
ThePaintedMan |
Apr 28 2013, 07:36 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Hmmm.. a search for Solex 32/34 or Solex progressive didn't return anything that looks like what Jason has. But DB is on the right track. You might need to pull the carb to verify this for sure... but I think it's a Solex C34. ->
http://www.shoptalkforums.com/viewtopic.ph...64&t=139538 What do you guys think? Jason, if you can find a rebuild kit, I can rebuild the carb for you. Or I/we can probably help you through it. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:13 AM |
