Carb question, need to dump little gas in carb just to get car started |
angerosa |
Apr 28 2013, 08:45 AM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
Seems that this year I need to put a little gas into the carb to get the car started initially. I have single Solex carb that no one seems to be able to identify. I'm sure some PO just pulled it off something that was sitting in a junkyard. Once I get car started and it warms up it idles OK but runs rough when you try to drive it. Timing is spot on. Recent (not too many miles ago) tune up with the help of some very knowledgeable 914world brethren. Let’s say it’s a given that there is nothing wrong with the engine. I have an idea of where to go next. I’ve had car for about 7 years. With only what I’ve told you here what’s your opinion?
angerosa |
Apr 28 2013, 04:10 PM
warpig |
Apr 28 2013, 04:33 PM
Member Group: Members Posts: 290 Joined: 2-August 10 From: Portland OR Member No.: 12,002 Region Association: Pacific Northwest |
I've got a set of dual weber 44's with manifolds and linkage, that need a rebuild, that I am not going to use if you want to upgrade. (carbs "and" motor) (IMG:style_emoticons/default/idea.gif)
angerosa |
Apr 28 2013, 08:20 PM
I've got a set of dual weber 44's with manifolds and linkage, that need a rebuild, that I am not going to use if you want to upgrade. (carbs "and" motor) (IMG:style_emoticons/default/idea.gif) I guess I can't use dual 44s on a stock 1.8 right? That'd be overkill. When the carb was working good, it was adequate and fun enough. I measured it to be 38. Some day I do want to upgrade the engine. I think I'm just looking to get my car dependable again at this point and if I can make it to the Deutschmarque Classic in Vienna, VA on May 5th that would be a plus. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:14 AM |
