Carb question, need to dump little gas in carb just to get car started |
angerosa |
Apr 28 2013, 08:45 AM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
Seems that this year I need to put a little gas into the carb to get the car started initially. I have single Solex carb that no one seems to be able to identify. I'm sure some PO just pulled it off something that was sitting in a junkyard. Once I get car started and it warms up it idles OK but runs rough when you try to drive it. Timing is spot on. Recent (not too many miles ago) tune up with the help of some very knowledgeable 914world brethren. Let’s say it’s a given that there is nothing wrong with the engine. I have an idea of where to go next. I’ve had car for about 7 years. With only what I’ve told you here what’s your opinion?
Mike Bellis |
Apr 28 2013, 08:28 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
You could go to your local auto parts store and get an electric choke kit to fit that manual assembly. It would replace the black part. Around $10. It would help with the cold start if the cable is not connected.
Lo-Fi Version | Time is now: 27th September 2024 - 01:18 AM |
