Carb question, need to dump little gas in carb just to get car started |
angerosa |
Apr 28 2013, 08:45 AM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
Seems that this year I need to put a little gas into the carb to get the car started initially. I have single Solex carb that no one seems to be able to identify. I'm sure some PO just pulled it off something that was sitting in a junkyard. Once I get car started and it warms up it idles OK but runs rough when you try to drive it. Timing is spot on. Recent (not too many miles ago) tune up with the help of some very knowledgeable 914world brethren. Let’s say it’s a given that there is nothing wrong with the engine. I have an idea of where to go next. I’ve had car for about 7 years. With only what I’ve told you here what’s your opinion?
Mike Bellis |
Apr 29 2013, 10:18 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
That's a big gap between the cam and pump arm. It almost looks like something is missing. A link maybe? Can you post some more pics of the cam and pump from different angles?
The cam should push the pump as soon as it moves from the idle position. |
Lo-Fi Version | Time is now: 27th September 2024 - 01:17 AM |
