Carb question, need to dump little gas in carb just to get car started |
angerosa |
Apr 28 2013, 08:45 AM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
Seems that this year I need to put a little gas into the carb to get the car started initially. I have single Solex carb that no one seems to be able to identify. I'm sure some PO just pulled it off something that was sitting in a junkyard. Once I get car started and it warms up it idles OK but runs rough when you try to drive it. Timing is spot on. Recent (not too many miles ago) tune up with the help of some very knowledgeable 914world brethren. Let’s say it’s a given that there is nothing wrong with the engine. I have an idea of where to go next. I’ve had car for about 7 years. With only what I’ve told you here what’s your opinion?
rhodyguy |
Apr 30 2013, 08:46 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
as he stated, the choke looks to be wired in the permanently open position. i think that carb is like a 2 barrel 4 barrel. the venturi with the throttle/choke plate on top is the primary. the other vent has the tp lower and does not crack open until the linkage activates it. consider verifying your fuel pressure. those chrome jobs are not known for their accuracy. the fuel filter should be prior to the pump. not after.
k |
Lo-Fi Version | Time is now: 27th September 2024 - 01:18 AM |
