1st auto-x next weekend, Next AX September 8th- only 7 points out of 3rd place with 3 events left! |
scott_in_nh |
Apr 13 2013, 05:56 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
74, stock 2.0, stock front swaybar - no rear bar, stock front inserts, may mount an older set of adjustable Koni's I already have on the back, either way 100 lb springs, 195/65 Eagle GT's.
Looking to have fun, not too worried about much else, but I have a few basic setup questions: I'm going to chalk the tires, but what pressure should I start at? Full tank, half tank or empty tank? Spare tire in or out? The konis need to be adjusted out of the car - soft, medium or firm (keep in mind I will have to live with it on NH streets too)? Should I overfill the oil a bit? If so how much? What am I missing? Thanks, Scott |
r_towle |
May 13 2013, 04:10 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
you will never do a burn out or powerslide with a stock 914.
You will however reset the suspension, which most other cars cannot do. Again...it goes totally against your gut and totally against how you learned to drive, but with THIS car, it works like magic. By the fourth cone, your back end is up in the air when you turn and all the weight is on the front outside tire. You touch the brakes, you spin. If you come off that third cone, just at the transition point, instead of turning, hold the wheel straight, brake hard, hit gas, turn hard. it takes practice...but it works very well for any turn in a 914. rich rich |
scott_in_nh |
May 13 2013, 05:48 PM
you will never do a burn out or powerslide with a stock 914. You will however reset the suspension, which most other cars cannot do. I've chirped the tires and slid while powered - doesn't that count (IMG:style_emoticons/default/confused24.gif) QUOTE Again...it goes totally against your gut and totally against how you learned to drive, but with THIS car, it works like magic. By the fourth cone, your back end is up in the air when you turn and all the weight is on the front outside tire. You touch the brakes, you spin. If you come off that third cone, just at the transition point, instead of turning, hold the wheel straight, brake hard, hit gas, turn hard. it takes practice...but it works very well for any turn in a 914. rich rich The club doesn't always set up such a long flush (6 cones) as seen in the videos (I can't find what they call it in AX, "flush" is a term we used ski racing to refer to gates in a straight line). I'll give it a try next time they do! I know I am not using the brakes as effectively as I might anywhere on the course.... |
Lo-Fi Version | Time is now: 27th September 2024 - 08:55 AM |
