Grinding into 2nd, SOLVED but new problem...which oil to fill? |
larss |
May 21 2013, 04:54 AM
Member Group: Members Posts: 429 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
After replacing bushings at my 914/4 -72 tailshift and re-adjusting the linkage I have a almost perfect shift in any gears and at any speed.
The only problem (right now) is that when starting cold in the morning (say 50-55F) there is a grind when shifting into 2nd. This is during the first minutes only, after that shifting into 2nd is like a dream again. The grind is wery noisy, almost as I try to get in reverse. I run Swepco 201. Any ideas? /Lars S |
Dr Evil |
May 21 2013, 08:01 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
You say it grinds like when you are going into reverse? It should NEVER grind going into reverse. That is a sign that your clutch is not disengaging all the way. Tighten your cable and see if your grinding in R and 2nd disappear. Also, your synchro band on 2nd is likely worn, but if a simple tightening of the cable clears this up then dont worry about it.
It is true that oil may take some time to get around, and things to warm up and work well, but the "grind into reverse" symptom is classic for something needing adjustment. |
larss |
May 21 2013, 08:24 AM
You say it grinds like when you are going into second? It should NEVER grind going into second. That is a sign that your clutch is not disengaging all the way... Thanks Yes, the only time there is a grind is when cold and going into 2nd. The sound is like if I was trying to put in reverse when the car is moving forward, wery high frequent. When warm everhing is O.K Will try tightening the clutch wire. /Lars S |
Lo-Fi Version | Time is now: 27th September 2024 - 12:03 PM |
