Sealing washer for the speedo drive, what is so special about it? |
malcolm2 |
May 20 2013, 08:29 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I see on the drawings that there is a $10 washer that I believe fits between the "bush guide" and the angle drive. At least that is my assumption. As I took mine apart, I had no washer. Why does it cost $10? Looks alot like an oil plug washer in my wifes Honda Van. I think they are Aluminum. $10 for a washer, wow?
Number 62 below. Porsche part # 914 318 261 01 I know this is the Sportomatic drawing, but the Manual tranny exp view has the seal and the the washer located ABOVE #61 (guide bushing), and that just won't work. Why a $10 washer? |
SirAndy |
May 20 2013, 09:37 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
It's more than just a washer.
It's a pretty thick "ring" that is a press fit to hold the seal in place. (IMG:style_emoticons/default/shades.gif) |
malcolm2 |
May 21 2013, 09:03 AM
It's more than just a washer. It's a pretty thick "ring" that is a press fit to hold the seal in place. (IMG:style_emoticons/default/shades.gif) So my washer might be in there, just pressed in? I can see the seam. Once I get the new one and the seal, I will pry it out, correct? Thanks, Clark |
SirAndy |
May 21 2013, 11:31 AM
So my washer might be in there, just pressed in? I can see the seam. Once I get the new one and the seal, I will pry it out, correct? Yepp, that's the one ... If you have a new seal, don't worry about messing up the old one. Makes the prying out of the ring easier. (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 10:40 AM |
