Transmission Leak, Side Shift |
Nor.Cal.914 |
May 26 2013, 04:39 PM
1975 914 3.0SC Group: Members Posts: 1,056 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
I just started driving my 914 again and have noticed a very small puddle of transmission fluid right underneath where the linkage goes into the transmission. It is a side shift setup. Is there some sort of o-ring that goes in there that I can replace to stop the leak? I've never removed that part of the linkage before so I don't entirely know how it goes together. Any help would be great! Thanks!
-Chris |
Highland |
May 26 2013, 04:47 PM
Senior Member Group: Members Posts: 526 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
check out this link. I have the same problem, but it's a small leak so I'm just going to change the seals the next time I change gear oil.
http://www.pelicanparts.com/techarticles/9...select_seal.htm |
Nor.Cal.914 |
May 26 2013, 05:09 PM
check out this link. I have the same problem, but it's a small leak so I'm just going to change the seals the next time I change gear oil. http://www.pelicanparts.com/techarticles/9...select_seal.htm Awesome! That is exactly what I was looking for, thanks! -Chris |
Lo-Fi Version | Time is now: 27th September 2024 - 01:01 PM |
