New engine rebuild running hot, Running Hot |
57lincolnman |
May 27 2013, 12:39 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
Recently completed rebuild of 1.8L and it's running too hot. Oil temps climb to 230 with only about 10 minutes running. It doesn't matter how the engine is loaded. Items to consider: 1) case cleaned and checked for alignment; 2) LN pistons installed at 96mm with new Nickie cylinders; 3) cylinder heads (1.8L) cleaned and set for 8.25:1; 4) new connecting rods; 5) push rods check out OK; 6) car did not previously have thermostat or cooling flaps, so these were installed. Thermostat opens as it should at 180; 7) Air/fuel ratio is 12-14 and within spec; 8) engine timing within spec; 8) mild cam upgrade. 9) crankshaft and flywheel were balanced; 10) all engine tin is in place
Could it be that the engine cooling flaps are not working or reversed? All thoughts and commentary are welcome. This one has us baffled. |
injunmort |
May 29 2013, 09:09 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
the timing sheet that is supplied with the cam, a degree wheel and dial gauge indicator. changing the duration and lift of the cam changes the cam timing.
Lo-Fi Version | Time is now: 27th September 2024 - 11:10 AM |
