Anyone ever use the stock alternator without the relay board?, Racers? |
stugray |
May 31 2013, 07:59 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I am guessing that someone else has tried this.
I have a stock alternator in my race car for now (upgrading to new 1-wire later). Relay board and entire harness is gone. I know that I need the external voltage regulator, so I decided I better figure out how to wire it up... It turns out that the plug from the Alt that goes to the relay board is exactly the same connector & pinout of the Voltage Regulator! So it can just plug right in... not so fast. For the alternator to startup/charge, it needs the voltage that is fed from the Alt light in the combo gauge. SO, can I just wire in a bulb from +12V and splice it into the D+ lead on that connector where it goes into the VR plug? Then the system should work exactly as before....?? Is the stock Alt bulb a special wattage? Stu |
McMark |
May 31 2013, 08:38 PM
QUOTE Then the system should work exactly as before....?? Yup QUOTE Is the stock Alt bulb a special wattage? Nope. |
mrbubblehead |
May 31 2013, 08:54 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
QUOTE Then the system should work exactly as before....?? Yup QUOTE Is the stock Alt bulb a special wattage? Nope. (IMG:style_emoticons/default/agree.gif) i just plugged my VR in and moved on to the next task. all tho, i use super brite LEDS for my idiot lights so i did have to wire a little incandescent bulb for the alternator. the led didnt pull enuff load by itself. |
Lo-Fi Version | Time is now: 27th September 2024 - 08:08 AM |
