More ratio madness (901), 2nd gear flipped 5th gear who knows huh? |
bondo |
Jul 9 2004, 04:26 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Ok, so I now know that for a good v8 5th gear, I need to put second gear in it's place.. flipped. 2nd gear is one 18 tooth gear and one 34 tooth gear. The 18 tooth gear is part of the mainshaft and not removable.
Then someone said the 904 mainshaft has no gears machines into it and all are equally swappable. But that is very rare, right? It's also more than I really need, as I just want the gear. But then it's been said that a 912 4 speed transmission has first gear where 2nd is on a 901, and the second gear is where third gear would be on a 901. Presumalbly this second gear is removable, and has the same splines on the inside as 901 gears. Is the ratio of this second gear something close to 18:34? Anything lower than 22:31 and it wouldn't be any taller than the stock 901 5th gear once it's flipped. I need sure answers here, I bought two 901s (no biggie, cheap) based on a statement something like: "you just flip 2nd gear and put it in place of 5th, and voila, taller 5th gear" which turned out to be nearly (see my signature) impossible. I do not want to buy a 912 4 speed to scavenge 2nd gear out of only to find it won't work or doesn't have the right 2nd gear ratio. (expensive) Just for the distribution of useful information, here are the ratios (tooth counts) of the stock 901 out of a 914 (side shift, but I don't think that matters) 1st (didn't count, but can if requested) 2nd 18:34 3rd 23:29 4th 27:25 5th 31:22 R&P 7:31 |
meursault |
Jul 14 2004, 12:42 AM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
Just to clarify a couple of things.
Early 911/912 gearboxes (65-68) were cast aluminum, so the housings should be stronger, but the differentials were weaker. You'd have to get around differential/ drive flange difference issues, venting differences, and nosecone/intermediate plate compatability problems to adapt the housings for a 914. Probably not worth the effort. You can't do a 2nd/ 5th flip because 2nd is permanently attached to the mainshaft. On a 4 speed box, the gear is still permanently affixed, but now that gear is 1st gear instead of 2nd. I don't think anyone here wants to build a 901 box with two 1st gears... GA mainshafts are pretty much standard fare in 911 gearboxes. |
Lo-Fi Version | Time is now: 27th September 2024 - 04:31 PM |
