FS -misc 914 parts - more added 9/3 - Revised prices, More and more parts coming out of the woodwork |
BS Chairman |
Jul 10 2013, 05:50 PM
Member Group: Members Posts: 98 Joined: 27-December 02 From: Southeast Michigan Member No.: 28 |
FS misc 914 parts - Revised prices
Newest Items Late Dash - VGC has one delaminiation at the corner of the left side gauge pod - $250 See Below Rocker Panels - See Below Windsheild gasket- See Below Blasted and painted trailing arms w/hubs- See Below Many newer items listed below. 1.8 FI computer $25 was running when switched to carbs L&R A Pillar cover w/plugs $25 Splash pan for under car. Blasted, painted, has some pits, tabs good $50 Door switch with gasket $5 Center/3rd Seat - Plastic tray decent, cracked hole. Center pad is solid, vinyl good $55 Early gauge set with silver buttons. Trip ODO unknown. $100 Headlight Motor Covers (pair) $20 no cracks Hood cable and pull - chipped paint - no key = $5 Ignition cylinder lock w/key we think it's late 71-73 - $5 Side marker Lens, crack on top - free with other purchase Side Targa Strip, the ones on the top, not the rear strips - so/so condition $5 Defroster vents -later cars w/center defrost $10 Will give discount for multiple items All items are plus shipping I take PayPal Attached image(s) |
BS Chairman |
Jul 25 2013, 03:07 PM
From top left, down and then to right
Late model Jack Straps, good rubber - $10 pair (4) 2.0 wheel caps, crusty, dinged, $15 pair (2) headlight motor actuator screws $10 pair Side Shifter Transmission Coupler $30 Rear Trunk Top Latch Mechanism (plastic spacer has wear spot $25 (2) round relays - $10 each Shock Rubber (4) , spacer (2) and 2 caps - $10 Set Door stay $15 Koni Adjustable shock adjustment knob - $10 Rocker Panel Jack point covers $10 pair Cigarette Lighter $30 - Bezel is so so Bag of 5 Fllywheel bolts, Torqued once $10 Rubber covers for rear shock tower $12 pair Plus shiping Attached image(s) |
Lo-Fi Version | Time is now: 27th September 2024 - 08:26 AM |
