Oil system diagram, and oil cooler installation & routing |
stugray |
Aug 15 2013, 02:24 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I would like to design a dry-sump type of system for my race car.
One thing I have found is that diagrams that show how the stock system works and how to modify it for other parts (coolers, dry sump, "full flow",etc) are hard to find. So I made this diagram in Visio (CAD-like) so I can move parts around and ask the proper questions. Does anyone have any suggestions or comments about making the diagram 100% correct before I start trying to modify it? (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1376598242.1.jpg) I could provide the original file, but not too many out there have visio. My next step is to get out a spare case so I can see EXACTLY where these parts go, exactly what any adapter might look like, and identify where all of the galley plugs would be in the diagram. Stu |
ChrisFoley |
Aug 16 2013, 06:40 AM
I am Tangerine Racing Group: Members Posts: 7,964 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'm developing a kit to delete the stock cooler completely.
I think they are ineffective, especially on modified engines, and the cooling air from the fan would be better used on the cylinders. The kit will include a take-off for a remote cooler which can go anywhere the user likes. I also don't much like the sandwich plates or the "full flow" case mods commonly used. They add unnecessary complexity to the assembly. |
worn |
Aug 17 2013, 10:42 PM
can't remember Group: Members Posts: 3,342 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I'm developing a kit to delete the stock cooler completely. I think they are ineffective, especially on modified engines, and the cooling air from the fan would be better used on the cylinders. The kit will include a take-off for a remote cooler which can go anywhere the user likes. I also don't much like the sandwich plates or the "full flow" case mods commonly used. They add unnecessary complexity to the assembly. Hi Chris, I want it. Do I have to drop the engine? Also, how is the fan flow rerouted. Thanks for taking this on. You do great stuff. |
ChrisFoley |
Aug 18 2013, 07:33 AM
Hi Chris, I want it. Do I have to drop the engine? Also, how is the fan flow rerouted. Thanks for taking this on. You do great stuff. Removing the cooler really isn't much more difficult than replacing the seals with the engine in the car. The 3 studs need to be removed anyway, to be replaced with short studs or 20mm hex head screws. The fitting adapter is much like an old type 1 remote cooler adapter but designed to route the hoses where we need them. The right side cooling flap will be replaced with a fixed piece which closes off the oil cooler air passage completely. To my mind this is a far better setup than either a sandwich plate cooler takeoff or a full flow case modification. The stock filter is retained with no mods, therefore the filter bypass is unaffected, and there is no interference with engine mounts, etc. A remote thermostat is incorporated in the hose routing, and a choice of rear or front mounted cooler is easily accomodated. My barebones kit will terminate at the thermostat, leaving the user to select his cooler of choice and supply the appropriate hoses. I've discovered that even the stock cooler mounted in a less than ideal remote location provides better oil cooling than when mounted on the engine and cooled by shroud blown air. |
Lo-Fi Version | Time is now: 23rd November 2024 - 01:39 AM |
