Problems with 914 2.0 ignition, 123igntion doesn work |
sebastian-914fan |
Aug 24 2013, 02:14 PM
Newbie Group: Members Posts: 12 Joined: 4-April 05 From: Germany, Mainz Member No.: 3,868 |
Hello,
after over 5 years of restauration for my 914 2.0 1973 the car is on the Road of germany again. I think it is very nice but I had to do much on the engine and the injection. So now i want to improve the ignition and bought an 123ignition distributor. It is also available for cars with injection now. So yesterday i installed the distributor, connected the red cable of the distributor with the new ignition coil checked the ignition with the timing LED, then connected the black wire with the igniton Coil, installed the cap, the cables and everything and tried to start the engine. But the engine did not start and there is no spark. Seems the engine gets fuel but no spark. Now i reinstalled the old 009 distributor and the engine starts easily. I posted my problem in the Forum of 123igniton and someone told me, that the ignition switch could be the problem and i should connect the distributor direct with 12v power source. I guess i can take these 12v direct from the battery + instead of the ignition coil or am i wrong? Are there any othe tips you may have for me? Hope my english is not too bad and my new ignition will work like an new in the next days. Thanks for help! :-) Greetings from germany Attached thumbnail(s) |
Nine_14 |
Aug 24 2013, 03:44 PM
Member Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany |
Use a "Prueflame" or Voltmeter to check out if you have voltage on the coil, but i am shure there is, otherwhise the old distributor wouldt not worki. Maybe the new one is damaged .....(distributor rotor is installed) ?? (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 27th September 2024 - 09:35 AM |
