Engine Seems To Run Hot, Even on cool days |
Mblizzard |
Sep 15 2013, 04:18 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok so I have been driving my new 2056 with dual webers an a SVDA dizzy with electronic ignition. Timing is set at 30 btdc. It seems like when I am on the interstate the temp gauge seems to ride at about 75% of the way toward hot.
The flaps should be set correctly and the thermostat seems to be allowing the flaps to move completely. As it moves toward hot I notice a lot of pinging. Plugs don't seem to be running hot or lean by looking at them. I am going to look at the flaps with my scope to verify the position but what to check after that? |
eyesright |
Sep 15 2013, 06:00 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
I agree that the IR thermometer is a good investment. I got mine from my local HR for about the same price. I have VDO aftermarket gauges and from the negtive feedback I've seen I wanted to calibrate them.
My oil temp after last night's drive was 210 F by the VDO gauge. The IR thermometer on the sump and the bottom of the oil filter showed the same. I've seen here that the red zone starts at 300 F on the stock gauge. An IR thermometer will help you know where you are in the white zone. Or a dipstick thermometer... |
Lo-Fi Version | Time is now: 27th September 2024 - 08:56 AM |
