Engine Seems To Run Hot, Even on cool days |
Mblizzard |
Sep 15 2013, 04:18 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok so I have been driving my new 2056 with dual webers an a SVDA dizzy with electronic ignition. Timing is set at 30 btdc. It seems like when I am on the interstate the temp gauge seems to ride at about 75% of the way toward hot.
The flaps should be set correctly and the thermostat seems to be allowing the flaps to move completely. As it moves toward hot I notice a lot of pinging. Plugs don't seem to be running hot or lean by looking at them. I am going to look at the flaps with my scope to verify the position but what to check after that? |
Mblizzard |
Sep 15 2013, 06:39 PM
Good point! Ordered one. Will check temps.
Any thoughts on pinging? Reduce advance? |
r_towle |
Sep 15 2013, 06:54 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Good point! Ordered one. Will check temps. Any thoughts on pinging? Reduce advance? If its pinging, you need to reduce the advance today...don't wait till you wreck something. 3 degrees to much could cause a lot of heat. 27 degrees overall advance it what the stock motor and camshaft can handle, no more. Rich |
Lo-Fi Version | Time is now: 27th September 2024 - 08:52 AM |
