Engine Seems To Run Hot, Even on cool days |
Mblizzard |
Sep 15 2013, 04:18 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok so I have been driving my new 2056 with dual webers an a SVDA dizzy with electronic ignition. Timing is set at 30 btdc. It seems like when I am on the interstate the temp gauge seems to ride at about 75% of the way toward hot.
The flaps should be set correctly and the thermostat seems to be allowing the flaps to move completely. As it moves toward hot I notice a lot of pinging. Plugs don't seem to be running hot or lean by looking at them. I am going to look at the flaps with my scope to verify the position but what to check after that? |
Krieger |
Sep 15 2013, 07:01 PM
Advanced Member Group: Members Posts: 4,754 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Reduce the advance a few degrees or get higher octane gas. If the higher octane doesn't do it reduce the timing. If you don't do something you will destroy the motor...
Lo-Fi Version | Time is now: 27th September 2024 - 08:57 AM |
