Side shifter console measurement needed, for the shift lever |
Phoenix-MN |
Oct 13 2013, 08:33 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
jimkelly |
Oct 14 2013, 08:37 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
why are you " making a longer arm" ??
are you going cable shift, or are you trying to lengthen your shifts, or ... ? I've seen pics of welded consoles, so you may not be fully limited by the edges of the console. |
r_towle |
Oct 14 2013, 08:42 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bob L. |
Oct 14 2013, 08:54 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
why are you " making a longer arm" ?? are you going cable shift, or are you trying to lengthen your shifts, or ... ? I've seen pics of welded consoles, so you may not be fully limited by the edges of the console. Longer arm =shorter shift Depends on which arm you are referring to. If you lengthen the one pictured, wouldn't in lengthen the shift. The end would have to swing a larger arc to move the innerds the same amount. |
Lo-Fi Version | Time is now: 27th September 2024 - 02:10 PM |
