New 'Hobby' Project, carb tuning gone high tech |
McMark |
Oct 15 2013, 10:39 PM
EDIT: I know about tube-and-water setups. You can't drive with those. I'm building some different.
I've been pondering this project for awhile, and now I'm finally getting ready to start. Every time I synch carbs I think about how terrible and approximate the process is. What I'm going to try is using a small, programmable computer called an Arduino. There are add-ons called Shields to expand the functionality, and I'm using a LCD screen shield. I'm going to hook up 4 to 6 MAP sensors to the Arduino and output their readings on the screen. Using this tool, I'll be able to numerically evaluate the relative balance of the carb throats. One possible shortcoming is that the intake pulses may create fluctuating values that are difficult to interpret. Although, I have some ideas that may deal with this. Some sort of averaging could help. (IMG:style_emoticons/default/idea.gif) Here's what the Arduino looks like (this is the Uno version) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898348.1.jpg) Here's the screen shield (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898349.2.jpg) Here's the MAP sensors I'm going to start with. (IMG:http://www.914world.com/bbs2/uploads_offsite/thumbs4.ebaystatic.com-419-1381898350.3.jpg) I'm also probably going to have to make some plates that will go between the carb and manifold with a vacuum port on it. This would be the easiest way to access manifold vacuum since I can't count on carbs to have vacuum ports. Oh, and this will also be useable while driving to evaluate dynamic synch. |
JStroud |
Oct 16 2013, 07:51 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Sounds like a good idea, Surprised nothing like that already exists, carbs have been around awhile, and the better synced the better they run.
Putting a plate between the carb and manifold seems like it would work to get a vacuum port....but when cars come in to be tuned, you would have to put a plate under each carb first, seems like something that could clamp/attach to the top with a vacuum port would be more universal and easier to use on all cars, just a thought....what do I know....I hate carbs. (IMG:style_emoticons/default/shades.gif) Jeff |
Lo-Fi Version | Time is now: 27th September 2024 - 05:34 AM |
